truck won't start
Old Oct 25, 2007 | 03:57 PM
chele's Avatar
chele is an unknown quantity at this point
Default truck won't start
Alright so as a disclaimer i just barely started working on vehicles myself due to lack of money so keep car terms simple because my knowledge is limited. Anyway I own a 1983 chevy blazer, it has a 350 engine that was completely rebuilt last summer. It ran fine other than the fact that after I shut it off it would sit there and 'rumble" for about 15 seconds then it would throttle up and finally shut off. I was told that the fuel was possibly running too rich and that i needed to re-jet my carbeurater. I did that and the only thing that changed was it started idleing way too low. Now about two weeks later it won't start period. It turns over and acts like its gonna start but doesn't. Any ideas? I'm really getting sick of walking everywhere lol
Old Oct 25, 2007 | 05:23 PM
thegr81's Avatar
Default RE: truck won't start
after you adjusted your carbeurator did you adjust it back? now to keep it simple like you asked you need to check for the major 3 when in a no start situation is it getting air, is it getting fuel, and lastly is it getting spark? look for all of these also when you go to crank on it is it a strong crank or weak crank? just a few questions to get the diagnostic started. let us know and then we can go from there.
Old Oct 25, 2007 | 05:51 PM
rriddle3's Avatar
Sounds like engine run-on, a.k.a. dieseling. Here's a link to an article from an MG site that explains the possible causes in pretty clear language. See if any of them might apply to your engine and let us know if you need more info.
Old Oct 25, 2007 | 08:47 PM
chele's Avatar
In response to your first question, I have not readjusted the carb. It's definitely getting air and fuel, spark i'm not so sure about. the crank is very strong, like i said it sounds like it would start up if you just choked it a little but that doesn't work.
Old Oct 25, 2007 | 08:55 PM
thegr81's Avatar
ok test for spark and let us know what happens.
Old Oct 28, 2007 | 01:34 AM
chele's Avatar
ok tested for spark...absolutely nothing.
Old Oct 31, 2007 | 02:16 AM
aris_unlimited's Avatar
aris_unlimited is an unknown quantity at this point
well if the motor is turning over you can pretty much figure your starter is good. I would start by checking the coil and see if that is putting out power. If not replace the coil.
Old Oct 31, 2007 | 06:13 PM
corr33's Avatar
corr33 is an unknown quantity at this point
Pop the distributor cap and see if the rotor spins with the engine when cranked?
Charder
Dec 8, 2013 08:30 PM
speedfreak81
Dec 15, 2009 11:47 PM
99whiteblazer
13
Jan 8, 2008 06:45 PM
hillbillyinOhio
Engine & Internal
Feb 21, 2006 11:49 PM
il67bp
Aug 29, 2005 12:16 AM
