tune up help
Old Jan 12, 2012 | 10:40 PM
lprovost's Avatar
lprovost is on a distinguished road
Unhappy tune up help
so I know this is a dumb question, but im having a hard time with it. I did a tune-up a month ago and when it came to the spark plugs, I could only get three out. Just seems like theres no room to even get a hand on them let alone a socket. Is there a secret trick or special tool? Please help me out!
Old Jan 12, 2012 | 10:46 PM
Little Roober's Avatar
Little Roober is on a distinguished road
The easiest way is to remove the tire on the side you're working on. Then Use a spark plug socket and extensions/wobble joint. (or whatever it's called) For the driver's side, turn the steering wheel to get a little more room next to the steering shaft. You should be able to get all of them out using the socket, extensions and wobble joint thing. Also a breaker bar may be needed.
Good luck,
Steve
Old Jan 15, 2012 | 09:39 PM
lprovost's Avatar
thanks. wow, never would have thought to do that. awesome
Old Jan 16, 2012 | 08:27 AM
You would have if you checked out the Tech Article (DIY) Index post and clicked on the #3 Sparkplug Removal thread. The index is linked to from the home page and has a LOT of useful information in it.
MikeChevyBlazer
Feb 4, 2012 12:08 PM
AreaCode215
Nov 7, 2011 03:07 PM
IronMan
Sep 21, 2011 11:28 PM
Phantoms001
May 16, 2011 05:35 AM
Redeye2000
26
Apr 5, 2011 11:54 PM
