v8 swap on my 95 chey blazer
Old Aug 11, 2009 | 05:25 AM
dueses's Avatar
dueses is on a distinguished road
Default v8 swap on my 95 chey blazer
hi i want to swap out my v6 engine with a v8 engine what is the best car engine to do this with i was thinking about 2005 trailblazer v8 will it fit if not what do you think i sould do thanks
Old Aug 11, 2009 | 07:57 AM
oktain's Avatar
did you search this topic? It's been discussed. I believe a direct bolt in car engine for 95 would be the LT1 out of a camaro/firebird if you're looking for a car engine. The intake design of a truck engine will require either a 2" body lift or a cowl-induction hood for the extra room needed for the intake.
There's another reason you need an engine from this period, something about OBD ports. I think your 95 is an OBD 1, and anything newer than that really is OBD 2, which will cause some headaches. Hence going with the LT1 out of a ~95 Camaro would be your best bet.
Correct me if I'm wrong folks.
Old Aug 11, 2009 | 04:38 PM
NVANZEE's Avatar
i think any 350 will fit from the same year range. Not sure on the OBD stuff. I guess your first step would be to find out if yours is OBD 1, 1.5 or 2
94BlazerGirl
Aug 28, 2014 06:14 PM
jjstyle
Jul 29, 2014 06:53 PM
PogiMoto
Jun 2, 2014 11:31 AM
Rick31108
Jun 27, 2011 05:45 PM
Phillips8201
Mar 16, 2010 10:26 AM
