v8 swap on my 95 chey blazer
did you search this topic? It's been discussed. I believe a direct bolt in car engine for 95 would be the LT1 out of a camaro/firebird if you're looking for a car engine. The intake design of a truck engine will require either a 2" body lift or a cowl-induction hood for the extra room needed for the intake.
There's another reason you need an engine from this period, something about OBD ports. I think your 95 is an OBD 1, and anything newer than that really is OBD 2, which will cause some headaches. Hence going with the LT1 out of a ~95 Camaro would be your best bet.
Correct me if I'm wrong folks.
94BlazerGirl
Aug 28, 2014 06:14 PM
PogiMoto
Jun 2, 2014 11:31 AM
Rick31108
Jun 27, 2011 05:45 PM
Phillips8201
Mar 16, 2010 10:26 AM
