vacuum leak?
Old Jul 24, 2008 | 08:25 PM
542jerry's Avatar
542jerry is an unknown quantity at this point
Default vacuum leak?
Vehicle: '93 S-10 Blazer 4 x 4 4.3L
Recently I started my blazer and it started fine. Got out on the road then approx. 1/2 mile from home started runniing rough, thought I would not be able to turn around andget back home. So the next day I started it up and same thing. I pulled off the vacuum hose on the brake booster and it smoothed right out. Plugged it back to booster and same problem rough idle and now dying. As long as I have the vacuum hose disconnected from brake booster it runs fime(although a little above normal idle rpm) and when I plug back to booster or even just place my thumb over the vacuum hose it dies. I have already replaced the brake booster with no difference.
Any help or suggestion will be appreciated.
Old Jul 26, 2008 | 08:45 PM
jones2008's Avatar
jones2008 is an unknown quantity at this point
Default RE: vacuum leak?
follow your vaccum lines your brake booster isnt the culprit
Old Jul 27, 2008 | 08:16 AM
raylo's Avatar
raylo is an unknown quantity at this point
Maybe sticking EGR.
cjb2145
18
Oct 6, 2018 04:46 PM
Jharper
Dec 19, 2007 08:47 PM
kfk4nf
Nov 2, 2007 09:59 PM
magnum434
Aug 15, 2006 12:39 PM
doom1701e
Sep 8, 2005 09:16 AM
