valve guide seals going bad?
Old Feb 13, 2008 | 08:27 PM
kerander's Avatar
kerander is an unknown quantity at this point
Default valve guide seals going bad?
The car'slower intake manifold gasket started leaking coolant into the oil and when I got the manifold off, I saw this
The passage in the lower picis chock full of this oily gunk and the upper manifold under the plenum has a lot of oil in it as well, which appears to be connected. I read somewhere that this may indicate a need to replace the valve guide seals. Is this correct? The car is running well otherwise.
Old Feb 13, 2008 | 08:37 PM
Default RE: valve guide seals going bad?
Leaking valve seals and/or loose guides shouldn't cause the whole runner to get built up with carbon like that, but I guess it is possible... A better indication would be the buildup on the back of the valve, but the only real way to take a look at this would be to pull the heads and if you were going to go that far, you might as well get them refurbished anyhow.
Old Feb 14, 2008 | 03:41 PM
kerander's Avatar
Could it be leaky valves or bad rings instead? Or, if it's running well could it just be cleaned up?
I had a problem with the fuel pressure regulator goingouta while back where it was getting horrible gas mileage - and I know the previous owner was running low quality gas through it for quite a while. Do you think these could have had an effect on it or caused it?
Would a leak down test be worthwhile? I'd like to avoid pulling the heads unless it's really necessaryof course.
bertrenolds
Nov 7, 2012 03:05 PM
drb
Apr 10, 2010 09:44 PM
lakeblazer91
Feb 18, 2009 10:06 AM
speakerwire
Sep 26, 2008 10:46 AM
curse
May 14, 2008 06:20 AM
