valve stem seals replacment
Old Sep 25, 2008 | 01:04 PM
speakerwire's Avatar
speakerwire is an unknown quantity at this point
Default valve stem seals replacment
What is the procedure to replace valve stem seals with the heads on?
Which valve stem seals should be used; O rings or umbrella style?
Old Sep 25, 2008 | 04:38 PM
Default RE: valve stem seals replacment
You will need an air compressor and the appropriate fittings to adapt to the spark plug hole. With that, you can start by removing the valve covers. Then the rocker arms. After that, you can use a valve spring compressor to push down on the spring, allowing you to remove the keepers. Finally, you can remove the old valve seals. Work one at a time.
You should buy a manual which should cover the torque specs as well as the requirements for tightening down the rocker arms once you are putting everything back together and running the final tightening sequence.
Old Sep 26, 2008 | 10:46 AM
I do not have an air compressor.
My main concern is what type valve stem seal does this forum suggest ?
bertrenolds
Nov 7, 2012 03:05 PM
boscoedoodle
16
Aug 16, 2012 04:53 PM
richphotos
Dec 14, 2011 10:25 PM
Imperator
Apr 27, 2010 11:10 AM
drb
Apr 10, 2010 09:44 PM
