VCM problem
Old Oct 29, 2009 | 09:35 AM
uphoosier's Avatar
uphoosier is on a distinguished road
Default VCM problem
My daughter's 1999 Blazer has been diagnsed with a VCM problem that prevents proper shifting of the transmission. The $425 price tag for a new one plus $110 for programming is beyond her means. Is a used VCM a viable option for her? Thanks for helping out.
Old Oct 29, 2009 | 10:01 AM
You may still have to incur the programming charge to get it to function properly.
Old Oct 29, 2009 | 11:06 AM
uphoosier's Avatar
Thanks for responding. Yes, I know. A local dealer quoted $110 for programming. Is a used VCM practical?
Old Oct 29, 2009 | 12:12 PM
Sure is. Many people do it even if they could afford new.
One thing you may consider. Getting a new PCM from a tuner to replace yours. It may be cheaper to get a core program PCM from PCMforLess.com tuned to your liking than to get a used PCM and have it programmed for your truck. The worst case is that you would have to get the CASE relearn performed which would cost you an additional $60 at most dealerships and less if you can find a competent mechanic with the proper tools.
Old Oct 29, 2009 | 01:28 PM
uphoosier's Avatar
I checked pcmforless.com and it looks like a viable option - with better performance to boot. Thank you so much.
Old Oct 30, 2009 | 08:20 AM
uphoosier's Avatar
The help here has been great, but I need a bit more. Seems a couple of different EPM part numbers were used on the 1999 4.3l vortec. Assuming I need to get to the old one to verify the part # before ordering. It's raining out, and I don't want to hunt for it. Where is it located?
Old Oct 30, 2009 | 06:48 PM
On the PCM itself. It may be visible or it may not be. The PCM is easy enough to remove.
terbates
May 7, 2012 05:41 AM
dootch
Feb 7, 2010 08:47 AM
haha29
Dec 1, 2009 09:55 PM
swallace8337
Oct 28, 2009 06:50 PM
catintat
Jan 31, 2008 07:54 PM
