In-vehicle rod bearing replacement
Old Sep 14, 2010 | 08:47 AM
blazercruzer's Avatar
blazercruzer is on a distinguished road
Default In-vehicle rod bearing replacement
Tip of the hat to everyone for their excellent posts. Many of them are very informative.
I'm going to change out the rod bearings in my '96 Blazer with the engine still in place. Does anyone have any tips or suggestions? Once I get the front t-case removed it appears to be clear for operation.
Old Sep 15, 2010 | 11:07 AM
Thor_449's Avatar
Thor_449 is an unknown quantity at this point
Don't put the connecting rod cap on backwards, remember to locktite and torque the cap nuts to specs, dont bang on it with a hammer too hard, mike everything, plastic gauge the bearing to make sure you have enough oil clearence
Old Sep 16, 2010 | 09:18 AM
Thanks for the reply Thor... I'll be tackling this over the weekend. I don't have much run time since the rod knock started (maybe 20min. or so), hopefully there's no further damage. It appears I could even remove the crank from under there if need be. I'll be sure to remember to scratch on the cap number while I remove them. Here's the crankshaft and rod bearing specs from the factory service manual.
Attached Thumbnails In-vehicle rod bearing replacement-blazer_crankshaft_bearingspecs.jpg
Old Sep 17, 2010 | 01:05 AM
old skool luvr's Avatar
that's "mic" everything Thor. as in micrometer.
unless you're getting "Mike" to do all the work.
sorry, been a long day (and i'm a machinist by trade), so i'm just gonna go now........................
brianp
Jun 1, 2020 10:30 AM
3D_Illustrator
Jul 21, 2013 07:24 AM
seriosbrad
Apr 23, 2013 09:24 PM
Klturi421
Aug 2, 2011 07:21 PM
TZFBird
Jan 20, 2011 10:17 PM
