vent hose leaking tranny fluid
Old Jun 1, 2015 | 08:14 PM
pacecountryboy's Avatar
pacecountryboy is on a distinguished road
Default vent hose leaking tranny fluid
my 97 4x4 s10 blazer has the 4l60E in it and as long as i dont drive it real far its fine but if i drive it more then 10 to 20 miles i start leaking tranny fluid from the vent hose and its a good leak to it gets on my motor and the exhaust and starts smoking i really want to figure out if this something i can fix or if i need to just go ahead and rebuild the tranny
Old Jun 1, 2015 | 11:49 PM
odat's Avatar
check your transfer case for fluid level [top big nut on the back side of the case] - if its over full the front seal in the transfer case is bad and its getting fluid from the trans - transfer case on the two that i have vents up there and the trans just has a inch or two long metal vent at the top of the trans
Old Jun 1, 2015 | 11:55 PM
I never even thought about that I will check it in the morning when I get up and see if its to full it should let fluid out when I take that nut off right
Old Jun 2, 2015 | 12:40 AM
odat's Avatar
if over full it will pour out - might be a quart or two might want to put a catch pan under it just in case
Old Jun 2, 2015 | 12:45 AM
if over full it will pour out - might be a quart o two might want to put a catch pan under it just in case
Ok good to know thanks for the info hope that I can figure it out its been driving me crazy it shifts fine and everythang just I have to make sure to keep an eye on the fluid level in it and thats it
porkfriedrice
Jul 3, 2013 02:51 AM
stereomike
Sep 19, 2012 05:07 PM
86TransAm
14
Dec 13, 2011 07:46 PM
builder125
Apr 17, 2011 09:20 PM
joker402
Dec 26, 2007 07:21 PM
