Water coming out of drain plug
Old Feb 26, 2022 | 05:51 AM
Mnm's Avatar
Mnm
Mnm is on a distinguished road
Default Water coming out of drain plug
I've got a 2001 2wd gmc jimmy sle with 170k miles . Blew my lower intake gasket and lost coolant , didn't overheat. I just got done replacing the lower Intake gasket , some hoses ,and sensors . As I was pouring water into my radiator to start doing a flush I noticed water dripping out of my oil plug . I'm very desperate to an answer especially since when I started this project there was no oil in the coolant .
Old Feb 26, 2022 | 10:03 AM
If there's no damage from overheating (cracks, blown head gaskets, etc.) and there was no water in the oil before you replaced the gaskets, the only logical explanation is that you messed something up when you did the gaskets. If they didn't seal correctly, they can leak coolant under the intake manifold, which will drain down into the pan.
Old Feb 26, 2022 | 11:10 AM
Mnm's Avatar
Mnm
That's exactly what I was thinking . I just wanted to make sure before I tear it all back apart .
christine_208
Sep 21, 2018 01:29 PM
genso
Jan 9, 2015 08:44 PM
wild bill
Apr 7, 2011 11:22 AM
JohnCG2002
Sep 2, 2009 10:26 PM
laurstevechar721
Nov 11, 2008 05:37 PM
