water leak
Old Dec 1, 2007 | 06:06 PM
mdish's Avatar
mdish is an unknown quantity at this point
Default water leak
i haveantifreeze leaking behind my a/c unit is there a freeze out plug located anywhere around there i have a99 blazer 4.3 vortec or what else can it be it is to high to be the water pump and all the hoses are good
Old Dec 1, 2007 | 08:37 PM
Default RE: water leak
I am afraid this sounds like a lower intake manifold leak, but other possibilities are the thermostat housing or a faulty upper radiator hose. The upper radiator hose wraps around behind the A/C compressor before continuing back up front to the radiator.
Old Dec 6, 2007 | 08:06 PM
mdish's Avatar
i found a hex plug in the block that is rusted out looks like the leak came from the intake man and was leaking for a while not to bad but bad enough and it ran down to this plug and the rest is history thanks for the feedback
kornphlake
17
Oct 10, 2008 01:20 PM
HillbillyDeluxe
Jul 31, 2007 01:41 AM
jpc10874
May 26, 2007 04:39 PM
ghenton
Sep 15, 2006 01:28 AM
45auto
Aug 18, 2006 03:09 PM
