Water Leak
Old Mar 26, 2014 | 11:57 AM
Bigmanisme007's Avatar
Bigmanisme007 is on a distinguished road
Default Water Leak
While underneath my 2000 Blazer, I noticed that the rubber vent at the bottom of the bellhousing has a leak of water that is ATF colored. The radiator is constantly low on coolant and as I refill it continues to leak. What should I be checking for?
Old Mar 26, 2014 | 08:36 PM
07nhbpsi's Avatar
07nhbpsi is on a distinguished road
Do a search on lower intake manifold gaskets..... it sounds like u are suffering from the notorious bad intake manifold gasket failure!????
Old Mar 27, 2014 | 12:14 PM
Could it possibly be a freeze plug in the rear of the block?
Old Mar 27, 2014 | 04:13 PM
TrevT1's Avatar
TrevT1 is on a distinguished road
I had a similar problem with coolant at the bottom of my block, and it was coolant from the intake gaskets. Do a pressure test on the cooling system to locate the leak.
Old Mar 27, 2014 | 05:07 PM
Thank you.
kornphlake
17
Oct 10, 2008 01:20 PM
HillbillyDeluxe
Jul 31, 2007 01:41 AM
jpc10874
May 26, 2007 04:39 PM
ghenton
Sep 15, 2006 01:28 AM
45auto
Aug 18, 2006 03:09 PM
