Water out exhaust!
Old Mar 25, 2008 | 07:25 PM
Dturner14's Avatar
Dturner14 is an unknown quantity at this point
Default Water out exhaust!
I have a buddy that I told I would ask on here about his truck. He has a 95 S10 Blazer 2WD and he was running it and it over heated pretty bad. It shut off on him as he pulled to the side. Now he has it home and it wont crank (Just turns over) and he had to put water in the radiator. now when he trys to start in a stream of water come out of the exhaust. I told him sounded like head/heads has cracked. What do yall think?
Old Mar 25, 2008 | 07:28 PM
Scooterewski's Avatar
Scooterewski is an unknown quantity at this point
Default RE: Water out exhaust!
Well, it sure doesn't sound good. I think that'd be a good guess...atleast in the right area. I had an old trans am that over heated on me pretty bad (due to a faulty gauge and a bad water pump) and I ended up replacing the heads. Does he have water in the oil also?
Old Mar 25, 2008 | 08:38 PM
Definitely sounds like a blown headgasket to me. Next step would be to pull the plugs. If coolant comes out, you've found the problem. If you don't find signs of coolant that way, a compression check would be the next order of business.
Old Mar 27, 2008 | 11:37 PM
AJBert's Avatar
I'll be nice and not say anything bad about your friend.
phatso_99blaz
Headers, Intake, & Exhaust
Apr 8, 2013 03:16 PM
BC1
Nov 14, 2010 10:55 PM
samuknow
29
Dec 10, 2008 10:41 AM
Blazer1305
Feb 20, 2006 12:52 PM
dobbist
Apr 13, 2005 11:26 PM
