Water coming out the exhaust?? big time !!!
Old Oct 25, 2010 | 06:00 PM
BC1's Avatar
BC1
BC1 is on a distinguished road
Default Water coming out the exhaust?? big time !!!
Need help or opinions !! I've a good stream of water coming out the exhaust pipe after changing a head gasket and intake gasket. I've read the posts on leaking intake gaskets but mine is really a major leak and I've changed both the head gasket and intake gaskets twice. Not my first rodeo, however at 70yr old, I might have lost my touch. It almost seems as though there is a passage I'm not catching.
data: 93 4.3L vortec / repaired a broken rocker post / no leaks before the rocker arm problem / head check for true / used felpro gasket set and reassembled / major water leak into cly and thru the exhaust system / stream out the pipe with billows of white smoke / water in oil / NO oil in water /
tore it apart used better gasket set and it produced the same results !
Tore the upper and lower manifolds off bought better gaskets clean the devil out of it reassembled and it's doing the same thing. Water out the exhaust / water in cyl / billows of white exhaust smoke.
I could use some help / I must be missing something. Any ideas?? Thanks BC1
Old Oct 25, 2010 | 07:10 PM
94BlazerPA's Avatar
94BlazerPA is on a distinguished road
My only suggestion is that your putting it on backwards.
My brother-in-law's car was leaking oil from the head gasket and it turned out he had it upside down and the gasket wasnt covering an oil passage.
Old Oct 25, 2010 | 10:19 PM
69chevelle's Avatar
69chevelle is on a distinguished road
or a cracked block? check your cylinder walls when/if you tear back into it. depending on where it is in the stroke it can leak into the block or cylinder
or it could be bypassing the rings to enter the block if the leak is major enough.
cracked head?
pitted or warped?(including block)
just some idea's. i personally have never had to do a head gasket
check your plugs and you might be able to tell what cylinder it's comming from.
Old Nov 14, 2010 | 10:55 PM
diablaroja's Avatar
diablaroja is on a distinguished road
any follow up to your problem? I have my heads removed right now from a 4.3. I have felpro gaskets and the only thing i noticed was the rear water port should be covered by the gaskets on both sides of the intake manifold.
blazer 572
Mar 18, 2014 07:45 AM
Joe Table
May 1, 2011 03:56 PM
77Nova
Aug 28, 2010 10:38 AM
Dturner14
Mar 27, 2008 11:37 PM
2001blazer
Tires and Wheels
Mar 9, 2006 02:39 PM
