Water Pump.
Water Pump.
Hey guys, I just wanted to know when should the water pump be replaced. On my '96, I have about 101,000 miles on it, and so far, all I have done is changed the thermostat, along with a few radiator flushes, and heater core being changed. My brother is going to have the water pump on his '00 blazer replaced. The reason why I am asking is because his has fewer miles than mine, and is newer, and I still haven't replaced my water pump. I have heard that if it is leaking, it should be replaced. I really haven't seen any leaking, and my truck hasn't overheated on me.
RE: Water Pump.
Don't worry about it. Replace it when it goes bad.
RE: Water Pump.
"If it aint broke, dont fix it"
RE: Water Pump.
Ok, but just to make sure, are the signs of a bad water pump overheating and leaking?
RE: Water Pump.
Im sure that could indicate a bad pump. I'm sure you would notice it leaking before you got to overheat the engine.
RE: Water Pump.
Ok, thanks a lot. I'm definitely not going to even bother with the water pump now that you guys say that, especially after spending money on repairs that I have already done in the past few days. lol Just wanted to know the signs. Thanks a lot.
RE: Water Pump.
I have a '00 with 146,000 miles and the original water pump. Pre Dex-Cool they would last 100,000 miles. Post Dex-Cool and I am trying to find out how long they last. So far 1 1/2 times the pre-dexcool coolant.
chipjumper
15
12-14-2019 08:49 AM
BouncingRadical
14
11-27-2015 12:30 AM
blazermanxx
14
03-27-2006 12:25 AM
