Weep hole wetness
Old Feb 1, 2012 | 11:46 AM
  #21
Vahomboy's Avatar
Vahomboy is on a distinguished road
Originally Posted by Jakethegreat440
If your see condensation around the weep hole on the water pump, I'd suspect it might be faulty or need to be replaced soon. I had a new defective water pump drip drop from the weep hole for a year before it started spitting out large amounts of coolant
Mine did that just recently, barely a drip for a while and when it went, seemed the whole bottom fell out the bucket. Last thursday's project, new pump, new T-stat and both hoses. Plus a flush and reservoir cleanout.
Old Feb 1, 2012 | 12:24 PM
  #22
pettyfog's Avatar
Nothing much has changed in pump tech in last 40 or so years AFAIK. It's a springloaded rotating carbon seal. If you have a dishwasher, much the same tech.
Miding the weephole is a good idea, but you'll probably see a drip-run stain. That will sometiems happen.
If it's always damp... fail is pretty much imminent.
Used to be coolant additives said something about pump bearing lubrication... Bull hockey.
Coolant should never get to the pump bearings.
Seal lube.. maybe. But there isnt any in a dishwasher, is there?!! Or you couldnt use DW detergent as a flush.
fondo
Aug 20, 2012 08:26 PM
Quick7
Mar 5, 2010 11:05 AM
Hanr3
Mar 6, 2007 09:09 PM
BlazerDaughter
Jan 22, 2007 08:17 PM
XBlazer01
Nov 24, 2006 06:36 AM
