Weird starting issue
Old Aug 14, 2018 | 10:03 PM
Dannyn01's Avatar
Dannyn01 is on a distinguished road
Default Weird starting issue
My BlaZeR2 has this weird starting issue where If I get in the truck put the key in he on position until the dinging sound stops and go to crank it, it will take a few seconds for it to start.
But then if I simply get in and just turn the key and not wait for the dinging sound it will crank fine with no issue. What could this be?
Old Aug 23, 2018 | 11:45 AM
DanD's Avatar
DanD is on a distinguished road
Default Weird start
Think about everything that has to work by turning the key. From the ignition switch to starter. Can you hear the fuel pump kick in? Does the steering wheel lock up or does the tilt adjust on steering column act funky or loose? Any of this could be one of Blazers quirky habits or the beginning of something going out in my 98. I can't always fix it but can usually track it down thinking bout it from point a to b.
pipeliner91
Jan 11, 2018 08:05 PM
01LtBlAzEr
Jun 12, 2012 08:23 PM
Rain
Mar 29, 2012 09:32 PM
nitromt
Dec 3, 2011 09:23 AM
Ape357
Jan 7, 2011 01:28 PM
