Well I only got 150k out of her...
Old Sep 8, 2011 | 08:21 PM
  #21
Silver00LT's Avatar
If I knew the tran mount was torn I would of ordered ES mount for it as well....just ordered the motor ES mounts(black BTW). lol I was like DANG it....so I am rocking a stock mount on it.
Old Sep 9, 2011 | 04:37 PM
  #22
Silver00LT's Avatar
She is running! I pick her up here in a few hours.
Old Sep 9, 2011 | 08:34 PM
  #23
Silver00LT's Avatar
She is back at home and running normal EXCEPT the selector square is no where to be found...having to go by instinct to know what gear I am in...also cruise control is inop now...hope it is just a unplugged sensor. I will be looking tomorrow after work.
She purrs beautiful and the OP is back at 50-60psi while driving WOOHOO. Temp stays at 195* without the assistance of fans. Temp was 70* with 60% humidity.
Old Sep 10, 2011 | 02:59 PM
  #24
They may have broken the park/neutral position switch...
Old Sep 10, 2011 | 03:29 PM
  #25
CaptainK's Avatar
CaptainK is on a distinguished road
Your cruise control could be unplugged or you could have a vacuum line off somewhere. The "Cruise" light on the IP disappeared on mine but the cruise still works. Check the vacuum canister that is on the hood to make sure it is plugged in. It would be an easy one to forget since it is about the last thing after you put the hood on.
Old Sep 10, 2011 | 04:39 PM
  #26
Silver00LT's Avatar
It was something simple...the retaining pin broke off. I just grabbed one from work and put it on. Cruise control is back to working.
However, this morning I cranked up to a failed TPS. That was fun driving to work then after work driving to Auto Zone. But it is fixed now.
I NEED that selector box to come back on as I am not the only that drives the vehicle...I do not need my fiance to get in with my two boys and accidentally go to the wrong gear. She tends to forget things so her having to remember something that she rarely does(drive my vehicle) I do not need it to slip her mind then the truck ends up going forward or backward into something or someone. I am going to get under and unplug the shift assembly on the side of the transmission and spray the connections with brake cleaner and let it dry out before I plug them back in. Probably got moisture in there due to the transmission got SOAKED with water and oil
Old Sep 10, 2011 | 04:41 PM
  #27
Silver00LT's Avatar
I will check this as well...tomorrow that way they can not say well you waited, etc. And send them the bill for the part. I am not driving an hour to the shop drop it off grab another rental then go back the following week just to pick it up. My work schedule does not leave me time to do that.
Old Sep 15, 2011 | 02:26 PM
  #28
chcknugget's Avatar
chcknugget is on a distinguished road
Man, that's a lot of coin to put into a blazer with trans thats not working right... In atlanta you could buy two good condition blazers for the same amount.
Old Sep 15, 2011 | 06:01 PM
  #29
Silver00LT's Avatar
Reman trans is going in after the OT season is done at work. Going to do it myself to save a few coin. A lot less stress than a engine, and I rather do 100 transmission installs than do a bloody T-case on a stryker again...you have to take the truck fully apart pretty much.
jimhens82
Apr 2, 2020 08:06 PM
bigjayxxy
Performance & Brainstorming
Oct 20, 2014 07:21 PM
bobby099
Mar 20, 2012 07:13 PM
Melrock83
Aug 1, 2011 01:32 AM
Bigblock396
Engine & Internal
Dec 4, 2007 04:13 PM
