what B&M trans cooler do you recomend?
Old Dec 13, 2009 | 09:10 PM
dunontme's Avatar
dunontme is an unknown quantity at this point
Default what B&M trans cooler do you recommend?
I want to help extend my trany life, I don't tow or off-road. What B&M cooler/item # do you think is best for me? Do these come with all needed hardware to install it?
Old Dec 14, 2009 | 11:08 PM
AJBert's Avatar
If you don't haul anything ever, let alone go offroad, save your money as you really don't need a tranny cooler. Just do the fluid and filter change regularly (~every 50,000 miles) and you should be good to go.
Old Dec 14, 2009 | 11:53 PM
old skool luvr's Avatar
i notice in your sig, that your truck really isn't running very stock, ie; rebuilt Proformance long block, CA Intake, HELIX Power Tower Plus Throttle Body Spacer. do you drive your truck hard at all? meaning, you've done quite a bit of work to her, do you enjoy it? 'cause if you do enjoy playing with it regularly, then you should get a cooler.
as for what size, i've always put in the biggest i could fit in. some vehicles don't have as much room as others, so try and find one that fits. also, have you tried a wreckers for a factory one? these are actually quite large (alot of tube length = larger cooling area) and bolt in nicely. i haven't changed the factory one on my '98 4 door, and i tow alot of stuff-including my 20 ft car trailer with no issues. plus it's the only truck around in the Winter for towing duties.
Old Dec 15, 2009 | 04:16 AM
dunontme's Avatar
I added all that after market stuff for fun cause I was board and the old engine went out because of my rag issue.. Ive posted that in this section. as far as driving style I like to race to the next redlight but thats about it.
Old Dec 15, 2009 | 03:18 PM
ahhh, i forgot that was you.
LannyL81
Mar 28, 2014 10:56 AM
mrspeedy69
Sep 25, 2012 12:13 PM
v8 jago
Suspension Tech
Oct 23, 2011 08:31 PM
brian400ex
Jun 22, 2010 10:23 PM
