what might be the problem,no start,now fine
Old Jul 16, 2012 | 04:16 AM
int3414's Avatar
int3414 will become famous soon enough
Default what might be the problem,no start,now fine
98 s10
sat over-night,no start in morning(starts but only runs for 1 second.
3 hours later starts,runs fine?
could it be the ,little finned box attached to the coil?
thanks for any suggestions
Old Jul 16, 2012 | 09:34 AM
BigBlu102's Avatar
BigBlu102 is on a distinguished road
Does it turn over or make a buzzing noise when you try to start it?
Two things come to mind.
When you go to start it, turn your key to "Accessory" (two clicks forward without starting it) and listen for a whining noise in the rear. eveytime it doesn't start do that to see if the fuel pump is engaging.
The other thing i would check is the starter motor.
Please give more details on what it does when it won't start or dies.
Old Jul 16, 2012 | 10:20 AM
brooklynRick's Avatar
brooklynRick is on a distinguished road
Had something similar, sometime it just wouldn't start or the electric would just cut out. My terminal battery to the wire was corroded, didn't even look like it though but someone suggested I cut the wire back a bit to expose fesh wire, put the terminal back on and never happened again.
could also be the battery and the temp outside? Need more info on what noises you hear etc. Does electric work?
Old Jul 16, 2012 | 01:34 PM
50lb_cat's Avatar
Could also be a bad distributor cap and rotor. No start and hard starting in damp conditions is a classic symptom. If it has been very humid that can do it as well. Try taking a hair dryer to it in the morning before you start it to dry out any moisture. If it starts, then replace them with delco.
djmehkae
Nov 7, 2017 08:08 PM
Stormedsoup
Mar 13, 2013 12:21 PM
davtak
Aug 30, 2010 10:36 PM
gERgMan
May 16, 2008 10:12 AM
epitaphoftwilight
Apr 5, 2007 03:18 AM
