-   -   What tranny do I have? (https://blazerforum.com/forum/engine-transmission-35/what-tranny-do-i-have-14880/)
bobslsc Nov 30, 2007 09:47 PM
Need help in determining what transmission I have. It is a '93 GMC Jimmy with 4.3 Vortec engine. The trans is starting to slip after 153,000 miles. I think I'll just look for a replacement tranny to swap, but what trans should I be lookin' for?
mdehoogh Nov 30, 2007 09:58 PM
RE: What tranny do I have?
700r4 ?
Chevy Lover Nov 30, 2007 10:06 PM
In '93 you would have either the 4L60 or the 4L60E. "E" is for electronic shift and you should have a wiring harness with a bunch of wires to the transmission.
Hanr3 Dec 1, 2007 12:04 AM
yep, on the S10-Blazer '93 was the first year of the electronic tranny. Prior to that it was the 700R4, then 4L60, and then the 4L60E. To verify crawl under the truck and look at the passengers side of the tranny. If you see a wiring harness, its a 4L60E, if you see a black cable, its a 700R4/4L60.
mdehoogh Dec 1, 2007 12:09 AM
[:@]i was off by a year
Hanr3 Dec 1, 2007 12:22 AM
ORIGINAL: otnietdehoooo
700R4/4L60/4L60E are basicaly the same trannies. I took teh clutch packs out of my '00 4L60E tranny and put them in my '87 700R4, and the '87 700R4 was a 60 degree tranny. That means it wont bolt up to a 4.3 or a V8.
GM used the 700R4 from the early '80s to the ealry '90s. Then it switched to the 4L60 until '93. In '93 GM went with the 4L60E.
Off by a year, not really. They are all basically the same thing. The only difference is the valve body and how its controlled. [8D]
bobslsc Dec 1, 2007 04:27 AM
Thanks for all the good info on the trannys. Now I need to locate one in decent shape.
Hanr3 Dec 1, 2007 12:41 PM
Why, rebuild your current one. 90% of the time when your tranny gets rebuilt it is better then stock. There are a bunch of little tricks rebuilders do to inprove teh performance and reliability of the tranny. A used tranny will cost you half a rebuilt one. Check the Self-Help Section. I did a write up on how to drop the tranny, that will save some cost. Installation is reverse of removeal.:D
bzmotoninja83 Sep 14, 2008 01:15 PM
edit: i have a 96 blazer 4><4 and got the trans from a 97 4><4
i bought a rebuilt one, even though used. it was rebuilt less than a year ago. wht only questions i have are this. the bad trans has a casting on it that reads 4l60e 3.3where as the rebuilt reads 4l60e 4.3. someone told me that someone swapped a 2wd trans in or its just a casting #. also the sticker on the top of the bad one says 6TAD where the new one has 7TAD. idk if thats a major diff. my main wuestion is whats the trick to getting the tranny back it? my mech had a hell of a day getting it out.... do we need to drop the oil pan to get at teh converter bolts?
swartlkk Sep 14, 2008 03:16 PM
No need to spread your question around...
