what is wrong with my s10
Old Apr 11, 2008 | 04:49 PM
jawheelsn's Avatar
jawheelsn is an unknown quantity at this point
Default what is wrong with my s10
[hr][hr]i need to know what to check on a vortec v6 93 been sitting its getting gas and spark but wont fire any ideas without going throw all electronic bs
Old Apr 11, 2008 | 05:02 PM
Default RE: what is wrong with my s10
Have you verified the fuel pressure is appropriate for the application? I am assuming that you have the CPI motor (large aluminum upper intake plenum having a black plastic cover on top with 'Vortec' in orange lettering). If that is the case then you need atleast 52psi of fuel pressure to start the engine. You will also want to check the bleed down of that pressure once you turn the key off. If it bleeds down quickly, you have a leak in the fuel system. Quite common for the CPI motors to have the FPR (fuel pressure regulator) fail.
Is the check engine light on?
Old Apr 11, 2008 | 05:37 PM
jawheelsn's Avatar
[hr]that might be the advise i need can you aim me at jawheelsn
Old Apr 11, 2008 | 05:43 PM
What is wrong with asking here? Someone else might have the same questions... Don't forget to use the search feature now that you have a direction to go with your diagnosis.
Old Apr 11, 2008 | 06:12 PM
jawheelsn's Avatar
[hr]im new to this and wasnt sure if i was doing right.with the bazer.i shot stsarter fluid down the opening at front where hose goes and still wouldnt start shouldnt it at least try to start it might have ran out of gas also.the digital dash doesnt show the fuel cause a bulb is out
Old Apr 11, 2008 | 06:15 PM
Well, if the FPR is shot, it could be extremely flooded. That is why you should test the fuel pressure. The fuel pressure test port is located on the rear driver corner of the upper intake plenum. You will need a fuel pressure gauge (~$20 from your favorite autoparts store) to test the pressure.
Old Apr 11, 2008 | 06:20 PM
jawheelsn's Avatar
[hr]you are really giving me some good ideas let me throw you a few curves?blazer sat for a yr ran good one day and not at all the next.when i give it any fuel at all it doesnt try to fire but if i dont give it gas it trys to fire.where is the fpr located
Old Apr 11, 2008 | 06:24 PM
FPR is under the upper intake plenum (again if you have the CPI engine - you still haven't confirmed that).
THIS THREAD should give you some good ideas on what is required.
I'm not saying that is the absolute cause of the problem, but it is a posibility. You have to do the fuel pressure test to tell for sure.
Old Apr 11, 2008 | 06:43 PM
jawheelsn's Avatar
[hr]if by cpi you mean with the high intake you descibed everything to a tee
Redeye2000
26
Apr 5, 2011 11:54 PM
97blazer617
Nov 17, 2009 08:31 PM
john50
Apr 13, 2006 01:45 PM
toofast2ride
Mar 30, 2006 12:29 PM
MusicMaverick
Feb 13, 2006 02:40 PM
