what's this hose for?
Old Mar 9, 2007 | 12:12 PM
erl982wd's Avatar
erl982wd is an unknown quantity at this point
Default what's this hose for?
Does anyone know what this hose is for, where it was attached? I found it hanging out of the passenger side fender well opening on my 1998 Blazer, just at the inside front of the tire. It looks like a drain hose of some kind, and it looks like it came from somewhere directly underneath the battery. It has about a 1 inch 90 degree turn and is around 6 inches or so long. Thanks for any replies.
Old Mar 9, 2007 | 02:34 PM
Chevy Lover's Avatar
Default RE: what's this hose for?
A picture and a little more info on your truck would be helpful.
Old Mar 9, 2007 | 02:35 PM
JustBlaze!'s Avatar
JustBlaze! is an unknown quantity at this point
Seems like it's the drain hose for you radiator. Look underneath your radiator, on the passenger side near the battery, there should be a drain where the hose will plug into.
Old Mar 9, 2007 | 03:15 PM
20Blazer00's Avatar
Might also be the overflow hose for the coolant recovery tank....
Old Mar 9, 2007 | 09:21 PM
Kordog's Avatar
Kordog is an unknown quantity at this point
ORIGINAL: JustBlaze!
That is exactly what it is for. When you pull the petcock, it will drain through the hose and not onto the core support.
Old Mar 9, 2007 | 10:26 PM
20Blazer00's Avatar
ORIGINAL: erl982wd
Here is a photo of the hose that is located on my 2000 where you say yours is...mine dumps right by the front drive shaft...it is longer than 6in..
[IMG]local://upfiles/1127/DDE94635AC88408D9FBE4A0CD88262F6.gif[/IMG]
Old Mar 10, 2007 | 01:04 AM
MNHawk's Avatar
MNHawk is an unknown quantity at this point
That is the over flow drain line, for like if it boils. It helps keep the overflow tank from expanding and then blowing. Kind of does like a pressure release valve on an air tank or a water heater.
Old Mar 11, 2007 | 02:12 PM
erl982wd's Avatar
Thanks to all for your help. Problem solved.
86TransAm
14
Dec 13, 2011 07:46 PM
rob1621
Apr 3, 2008 08:55 PM
Dizgt
Apr 8, 2006 10:59 PM
burcham
Nov 30, 2005 09:57 PM
vmx120
Sep 12, 2005 07:10 PM
