whats the part thats threaded into the driverside head?
Old Oct 27, 2012 | 04:36 PM
abig84's Avatar
Default whats the part thats threaded into the driverside head?
i thought it was the tempature sending unit, it looks like this
but that website says its a ignition knock sensor for a 1999 my truck is a 93 s10, does it even have a knock sensor. the wire is completely broken off and i been looking for a pig tail for it
edit... guess i found it. its called a
GM Coolant Sensor Knock Sensor Repair Pigtail
interesting. wonder if its a 2 in one sensor or something. my temp gauge wasnt working and that must be the culprit.
Old Oct 27, 2012 | 08:01 PM
richphotos's Avatar
Your truck has a knock sensor.
Old Oct 27, 2012 | 08:14 PM
chris015's Avatar
temp sensor is on passenger side of the block...what we see here is the knock sensor.
Old Oct 28, 2012 | 01:35 AM
97cherryblazer's Avatar
97cherryblazer has a spectacular aura about97cherryblazer has a spectacular aura about
Doesnt that live on the back side of the block by the distributor and oil pressure switch?? or is that only on newer models?
Old Oct 28, 2012 | 02:34 AM
Toby Hanson's Avatar
Toby Hanson will become famous soon enough
There are two knock sensors: one on the driver's side cylinder head and one on the back of the block below the distributor.
Old Oct 28, 2012 | 01:26 PM
abig84's Avatar
interesting, never knew that. this truck has been the most trouble free truck i have ever owned so never really had to mess with anything under the hood. i started it up today and let it run for like 20 minutes when i noticed the temp gauge hasnt moved and thats when i discovered this wire busted off.
jimspahr@msn.com
May 2, 2013 07:05 PM
spider21
Nov 17, 2011 06:27 PM
Bizzel
Mar 23, 2010 09:14 AM
dmc919
Sep 14, 2008 12:11 PM
jagblazer01
Sep 12, 2006 10:20 PM
