Starts with either, thats about it
Old Aug 25, 2008 | 08:44 PM
dmc919's Avatar
dmc919 is an unknown quantity at this point
Default Starts with either, thats about it
94 s10blazer, 4.3 auto. the problem is it wont start without either or unless it has been running and you turn if off, it will start back up. but when its cold or hot but been sitting for about 30min it wont start back up. i checked fuel pressure it's 58. it has new plugs, wires, cap, rotor about 3k miles ago. runs fine after it starts up. i'm thinking maybe worn out timing chain but wanted to get some other opinions before i tear apart the front of the motor. also it just started this a couple days ago, didnt gradually happen, just started happening instantly.
Old Aug 31, 2008 | 09:02 AM
dmc919's Avatar
Default RE: Starts with either, thats about it
I unpluged all the sensors on the moter and pluged them back in, made sure everything wasnt' loose and now it starts up just fine. what sensor does the motor need to start up but doesn't matter when driving?
Old Sep 14, 2008 | 12:11 PM
bzmotoninja83's Avatar
bzmotoninja83 is an unknown quantity at this point
oil pressure switch or a knock sensor or maybe even a temp sensor? i had the same prob on a 90 honda accord. i couldnt get it started on its own w/o starting fluid. turned out to be the coolant temp and the oil press sensor....
l8r dood
rexazz2
Jul 8, 2013 01:44 PM
abig84
Oct 28, 2012 01:26 PM
Cathy
Jun 22, 2010 11:39 PM
Bizzel
Mar 23, 2010 09:14 AM
jagblazer01
Sep 12, 2006 10:20 PM
