Where is the PCV Valve?
Old Dec 26, 2008 | 05:38 PM
bbqdporksammich's Avatar
bbqdporksammich is an unknown quantity at this point
Default Where is the PCV Valve?
Hiya, all!
Just bought a 1997 S-10 pick-up 4WD. I also bought a Haynes manual to see if I could find out how to fix a problem but I ran into a snag: I can't find the PCV Valve!
The manual shows pics of 3 engines and none of them look like mine. I know mine's a 4.3 and it says Vortec on the air cleaner cover. I thought the valve would be located on the right side (passenger side) of the engine and I pulled a plastic or rubber tube out of the rocker cover but there was nothing in it that even looked like a PCV valve. Would the valve still be on the cover after I pulled off the hose or would it be on the end of the hose? Maybe I'm not even looking in the right spot? This is just behind the alternator.
Any help here would be hot.
Thanks
Old Dec 26, 2008 | 07:18 PM
rriddle3's Avatar
Default RE: Where is the PCV Valve?
Look at the rear of the driver's side valve cover.
Old Dec 26, 2008 | 08:02 PM
Yep, driver side.
89Recon
Oct 22, 2011 05:50 PM
ricwin
Sep 30, 2008 09:56 PM
gscrippler
May 4, 2008 07:42 PM
Resolute
Dec 25, 2007 03:58 PM
blazinloud
Engine & Internal
Sep 14, 2006 12:08 AM
