White steam/smoke in engine compartment.
Old Oct 18, 2013 | 10:09 PM
Clann91's Avatar
Clann91 is on a distinguished road
Exclamation White steam/smoke in engine compartment.
Temp gauge goes all the way up and all the way down sporadically, and then when I stop the Blazer it starts spewing white steam/smoke from under the hood. It looks like it is coming directly from the middle of the engine. There is nothing coming out of the exhaust in the rear and there is a funny coolant like smell when my heat is on and sometimes even when i have the air off entirely. I have an appointment to have it looked at. the coolant is full up. Any ideas?
Old Oct 19, 2013 | 10:15 AM
HcHawks09's Avatar
does your heat still work? possibly a leak in you're heater core.
Old Oct 19, 2013 | 11:00 AM
newguy's Avatar
you can have a fine pin hole leak spraying anti freeze on your hot block causing the steam also
Old Oct 19, 2013 | 06:52 PM
Clann91's Avatar
Yea i was a half gallon low on coolant and the radiator cap area was full of gunk.. Still smoking though so Ive got an appointment for monday to have it looked at. Heater core sounds right though cuz it blowing cold air mostly now.
Old Oct 19, 2013 | 06:54 PM
newguy's Avatar
cold air cuz the coolant was low
Old Oct 20, 2013 | 11:01 PM
Clann91's Avatar
Fixed it myself. Heater core hose was blown and spraying all over the compartment. Radiator was leaking real bad. New hoses and some sealant and all new coolant and were running beautifully. Thanks guys for the ideas! Total cost came out to under $100.
Old Oct 21, 2013 | 06:59 AM
richphotos's Avatar
You did not use the stop leak did ya? the stuff that you add to the engine? oh i hope not.
Calamity
Jun 29, 2012 11:05 AM
big armo
May 12, 2011 11:43 PM
92blazer92
Jan 25, 2010 12:46 AM
SniperX13
Jun 11, 2006 03:00 AM
Shaftjohnny88
Jun 4, 2005 07:58 PM
