will a 305 bolt in 95 s10 blazer?
Old Mar 4, 2012 | 08:23 AM
kms's Avatar
kms
kms is on a distinguished road
Default will a 305 bolt in 95 s10 blazer?
A buddy told me a 305 will bolt in my 95 s10 blazer with the same motor mounts and trany as the stock 4.3. I was wondering if anyone could tell me if that's true or not cause I can get a 305 cheap
Old Mar 4, 2012 | 08:42 AM
duxtoyz's Avatar
duxtoyz is on a distinguished road
yes it will but ul have to move ur radiator or put an electric fan on, but y a 305? they r kinda junk u know?
Old Mar 4, 2012 | 12:21 PM
chris015's Avatar
You are going to have about as much power as your 4.3 now. Pointless to put a 305 in,unless you build it up,and by then,you might as well buy a decent 350 crate motor.
Old Mar 4, 2012 | 02:46 PM
kms's Avatar
kms
Will a 350 use the stock motor mounts and trany
Old Mar 4, 2012 | 03:17 PM
duxtoyz's Avatar
yes, its the same block as a 305 just different internals.
Old Mar 4, 2012 | 03:24 PM
CenTexBiker's Avatar
CenTexBiker is on a distinguished road
actually its a 350 minus 2 cylinders
Old Mar 4, 2012 | 03:48 PM
kms's Avatar
kms
Ok thank I'm gona see if I can find a cheap 350
Old Mar 4, 2012 | 03:51 PM
btw you will need to wire in for the 2 extra injectors
Old Mar 4, 2012 | 05:57 PM
duxtoyz's Avatar
a 350 is the same as a 305.......read the posts better. lol i know a 4.3 is 2 cylinders shorter than a 305......geez. jkjk
Old Mar 4, 2012 | 06:30 PM
abig84's Avatar
i put a 350 in a 95 a few years back. i was able to use the mechanical fan BUT i had to modify the firewall a bit, buy engine mount adapters, slide the engine back almost a full inch and put the radiator where the a/c condenser sits lol. so yeah kind of a pain. im just anti electric fan never had one problem. never overheated fan never hit. i miss this truck, i sold it when gas prices got outta control. it was just a stock 350 out of a van. with 4.11 gears and stock tires, it would basically do a one wheel peel all the way to 45 mph. wasnt gonna beat any camaros or anything, especially with the lack of traction but would whoop any 4cyl s10 that tried
