Will a transmission np236(4 button) transfer case fit np233 (3 button) transfer case
Old Jan 11, 2014 | 09:51 PM
Flyfishen's Avatar
Flyfishen is on a distinguished road
Smile Will a transmission np236(4 button) transfer case fit np233 (3 button) transfer case
Will a (2000 Jimmy) transmission with an np236 (4 button) transfer case fit in a (1999 Jimmy) with an np233 (3 button) transfer case?
The wifes' tranny is going and I have a spare tranny from a 236 (4 button) transfer case.
thanks for the help.
Old Jan 24, 2014 | 06:33 PM
Flyfishen's Avatar
Anyone have an idea on this?
Old Jan 24, 2014 | 06:56 PM
Diaita's Avatar
Yes, it should. I'm not positive mind you.
Old Jan 24, 2014 | 07:27 PM
Flyfishen's Avatar
That's what I was thinking too Diaita. The numbers on both tranny's are the same but I guess I won't know for sure until I actually start working on it. Unless anyone else knows for sure?
Hopefully it doesn't die until at least spring. It's cold up here in the winter.
Old Jan 5, 2018 | 10:28 PM
Kaliforniakidd's Avatar
Kaliforniakidd is on a distinguished road
new here gotta a 2001 blazer with a 4 button 236 transfer case was wondering if a 233 transfer case (3 button) from a 2000 gmc jimmy would work and what i would have to do to wire it
Old Jan 6, 2018 | 06:18 AM
oldeerslayer's Avatar
oldeerslayer is an unknown quantity at this point
98 to 02 trans are the same. Your 2000 should be broadcast code 0TAD and your 99 should be 9TAD if the tags on the top are still there. The first digit is the year. The 2nd is the vehicle model. (T is 4wd S-series) The last 2 are the actual model of the trans.
Both transfer case adapters should be the generic 5 bolt, so just leave it attached to the trans. You'll need a new adapter to TC gasket. Fel_pro 72769 $5-10 depending on where you get it.
I'd replace the TC input seal on the 233 while you have it out. They are known to go bad and will cause ATF migration from the Trans to TC causing the trans to use fluid and the TC to be over full. Don't want to have to go back in later for that. They're also $5-10.
Old Jan 6, 2018 | 06:22 AM
Just find another 236. The wiring would be difficult at best. Probably would require re-programming or replacing the TCCM among other things. With the 233 you would also loose the ability to put it into neutral if necessary. But remember the 236 shouldn't be towed any distance in neutral.
Old Jun 18, 2019 | 11:22 AM
Mo Mikey's Avatar
Mo Mikey is on a distinguished road
Default Will it fit????? Yes and no
Will it fit , yes it will fit . But you will have issues with control of the case and front axles. The np 233 case does not have automatic ooeration like the np236 . Also the front axle lock vacuum switch is on the np233 TC and the np236 TC uses a firewall mounted electric actuator for the front axle vacuum locker.
Dan Watson
Jul 28, 2019 07:25 PM
timsawyer2002
May 15, 2013 07:18 PM
soky25
Aug 26, 2010 02:58 PM
daron gorichar
Sep 20, 2009 10:57 AM
josh05
Apr 17, 2009 06:13 PM
