will this work????
Old Sep 25, 2008 | 06:33 PM
amp88fan's Avatar
amp88fan is an unknown quantity at this point
Default will this work????
i need a tranny for my 95 blazer 4x4 auto...i found a 4l60e that came out of a 96 trans am....coult the tailshaft be removed from this trns and my transfer case adapter be bolted to it then transfer case etc and make it work without a huge hassal?
Old Sep 27, 2008 | 01:53 AM
mnstrjim's Avatar
mnstrjim is an unknown quantity at this point
Default RE: will this work????
pry not. you have to change tail shaft housing and shaft. Advanced Adapters makes kits for this and they arent cheap. look in a junkyard, pry gonna have to give $600-$1000 for a good used one. rebuild costs anywhere from $800 to $3200 depending on what needs done and warranty that you get
Old Sep 27, 2008 | 03:09 AM
packofqtips's Avatar
packofqtips is an unknown quantity at this point
you would pretty much need the transmission rebuilt to swap the tailshaft
project85
Jan 15, 2015 03:23 PM
lowloudnproud1
Sep 2, 2010 07:12 PM
ragu
Jul 13, 2010 12:08 AM
(SWE)Anders
Nov 2, 2009 05:52 PM
hantayo13
Jan 12, 2008 12:34 PM
