wont start
Old Jun 15, 2009 | 02:16 PM
watsonmt's Avatar
watsonmt is an unknown quantity at this point
Default wont start
it has spark and gas it will sputter if i hold the gas to the floor i just put another tps on because it had gone bad and it fired right up i shut it off now it wont start....i can smell gas strong when cranking so i know its getting fuel...was really hope to go to the mud bog this weekend any ideas guys... oh ya and theres no check engine codes
Thanks Matt
Old Jun 15, 2009 | 04:23 PM
rriddle3's Avatar
Which vehicle?
Old Jun 15, 2009 | 04:32 PM
watsonmt's Avatar
the 1993 jimmy cpi
Old Jun 15, 2009 | 09:33 PM
Fuel pressure reading, in PSI? How about the leak down rate?
Just because you can smell gas, it does not mean that it is the appropriate amount. With the CPI motor, it is a good possibility that it is too much.
Old Jun 15, 2009 | 10:24 PM
watsonmt's Avatar
ok i dont have a gauge and i cant get one ill just have to get the part what all will i need to get just intake gasket and the regulator? or is there a kit to fix the regulator thats what it looks like on this page
http://www.s10extremist.org/tech_art...CPI_VORTEC.htm
Thanks Matt
Old Jun 15, 2009 | 10:48 PM
mech cb's Avatar
mech cb is on a distinguished road
If you can smell gas, that usually means your floodin it. I'd lean it out a lil'
Old Jun 15, 2009 | 10:57 PM
Not sure if Lindertech.com is still offering their updated kit or not.
A fuel pressure gauge would save you from opening up the plenum. If you do not wish to get one to diagnose the problem, then you will have to open up the plenum and visually inspect for a leak.
JimmyBlaze541
May 2, 2013 10:00 AM
bobby099
15
Nov 7, 2012 07:29 PM
FreeTime
Sep 8, 2012 01:38 AM
slammed95blazer
Oct 27, 2010 07:24 AM
jetsmy
Aug 1, 2008 10:10 PM
