Wont Start
Old Jun 28, 2011 | 07:56 AM
CrazySouthernBoy's Avatar
CrazySouthernBoy is on a distinguished road
Default Wont Start
I have a 97 4wd 4.3L V6. I went to start it this past weekend & it wont start. I do got power to the dash & radio. When I try to start it all I hear is a clicking sound. Now I think its the Starter but I want to be sure that is all.
Old Jun 28, 2011 | 11:28 AM
Is the battery showing a proper charge (>12.5V with the key off)?
Old Jun 28, 2011 | 11:56 AM
Its showing a little on 14v & We even Jump it too see if that would work & nothing.
Old Jun 28, 2011 | 12:00 PM
Are the connections at the battery, frame, and starter clean and tight?
Old Jun 28, 2011 | 12:02 PM
When I check the start a few min ago Its got some rust & their is a little hole in the starter
Old Jun 28, 2011 | 03:33 PM
chris015's Avatar
Get a hammer and beat on the starter and try to start it. Sounds like the starter committed suicide.
Old Jun 28, 2011 | 05:11 PM
My Boyfriends Truck's Avatar
My Boyfriends Truck is on a distinguished road
I just changed my boyfriends starter on his 94 s-10 blazer yesterday the solenoid was bad when I turned it over all I got was one click! Now he went to drive it home got a mile from home and the truck died today I changed the fuel filter and and the fuel pump quit tomorrow I am dropping the tank and checking the ground wire on the fuel pump! Good luck with your starter! Took me about a half hour to change it be careful of the transmission lines his were rusted and I put a hole in one and had to fix that too!!
Old Jul 1, 2011 | 06:36 PM
Default won't start
OMG!! I went through everything changed filter changed starter which the solenoid on the starter was bad started ran for 10 miles then died again! Please Please Please check all your ground wires and make sure you have good connections!! I spent an entire week changing things and going through everything racking my brain I had a loose ground wire on the fuel pump and now the truck is back running like a champ again!!!! I wish you luck I hope this helps!!!
Old Jul 2, 2011 | 10:51 AM
It does help, I just need to get under my truck & fix this week if I can. To busy trying to find a job.
JimmyBlaze541
May 2, 2013 10:00 AM
bobby099
15
Nov 7, 2012 07:29 PM
FreeTime
Sep 8, 2012 01:38 AM
slammed95blazer
Oct 27, 2010 07:24 AM
jetsmy
Aug 1, 2008 10:10 PM
