wont start up
Old May 9, 2007 | 11:40 PM
92on24s's Avatar
92on24s is an unknown quantity at this point
Default wont start up
i have a full size 92 blazer with a v8. the battery, starter, alternator, spark plugs are all brand new. sometimes the truck wont start and then all of a sudden it will. when it doesnt it wont even click over, i have to jump start it but when i put it on bat. charger it shows that i have a full charge. would should i replace or look at so i can fix this? i was thinkn to replace to ignition, any other ideas?
Old May 10, 2007 | 10:34 AM
fnbutch's Avatar
fnbutch is an unknown quantity at this point
Default RE: wont start up
i had the same problem once did you try cleaning off the terminals on the battery sometimes they can get pretty corroded and wont allow the ectricity to flow. If youve tried this and they are clean now i would look into your ignition switch.
Old May 10, 2007 | 11:51 AM
92on24s's Avatar
all the terminals are new i even swapped out the brain for the alarm with a new one so im gona try the swtich, thanks
JimmyBlaze541
May 2, 2013 10:00 AM
bobby099
15
Nov 7, 2012 07:29 PM
FreeTime
Sep 8, 2012 01:38 AM
slammed95blazer
Oct 27, 2010 07:24 AM
jetsmy
Aug 1, 2008 10:10 PM
