1982 GMC Jimmy Sierra Classic Speedo Querry
Old Sep 8, 2011 | 05:22 AM
malcolmorams's Avatar
malcolmorams is on a distinguished road
Default 1982 GMC Jimmy Sierra Classic Speedo Querry
I'm looking at purchasing a 1982 GMC Sierra Classic 4x4 LH Drive. I assume the speedo should be in mph, however the current owner informs me that it is in fact in km/h. could somebody please clarify what the original speedo for this vehicle was calibrated in? Thanks
Old Sep 8, 2011 | 07:59 AM
Could have been either stock. Someone could have swapped dashes as well. So long as the speedometer reads correct, I wouldn't worry too much about it.
Old Sep 9, 2011 | 01:19 AM
Thanks for your quick reply. I haven't been able to establish if the speedo reading is correct yet- there could be some discrepancy in speedo readings. Should the speedo go up to 100000 or only 99000 and if the vehicle has the original owners manual would that show any pictures that would remove any doubt regarding these querries?
Is this the right forum for this vehicle or is only for 1983 onwards?
Old Sep 9, 2011 | 07:53 AM
I thought I already moved this, but evidently not.
*Moving to Full Size K5 Tech*
Also, your cluster will be scaled to display which ever numbers are large in the speedometer. If the MPH numbers are large, the odometer will read in miles, not km. If the larger numbers are in km/h, then the odometer will be in km. It is far more common to have it be MPH and that is likely what you have.
Old Sep 9, 2011 | 02:54 PM
Great! & thanks again
Old Sep 10, 2011 | 02:21 AM
ramapge's Avatar
ramapge is on a distinguished road
The maximum speeds would be different too. Without running out to my truck I think the max speed says 120 mph. So the max speed on a metric speedo should be around 190 to 200 kph.
Old Sep 10, 2011 | 04:39 AM
I still need to know if the maximum distance travelled before the speedo goes round the clock is 99000 or 999000?
Old Sep 10, 2011 | 10:54 AM
ramapge's Avatar
Guess the bow-tie guys didn't have faith in their trucks or were too cheap to add an extra digit to reach a million.
Old Sep 10, 2011 | 02:32 PM
Many vehicles in that era had only 5 figures for the odometer. Nothing to do with faith or longevity.
fishing fanatic
Jul 7, 2013 09:28 PM
malcolmorams
Feb 2, 2012 11:29 PM
malcolmorams
Sep 15, 2011 09:43 PM
pothole987
Oct 5, 2010 07:35 PM
cr8390
Aug 21, 2010 09:35 PM
