1989 blazer transmission to engine brace bars
Old Feb 28, 2023 | 08:17 PM
Garysblazer's Avatar
Garysblazer is on a distinguished road
Default 1989 blazer transmission to engine brace bars
I recently replaced the stock engine with a similar engine from blue print engines. Everything bolted right up. The brace bars that are supposed to go from trans to engine have no place to land on the engine but they look like they could land on the motor mount bolt but thy are about 1 inch short. I had some guys help me and nobody remembers where they went. Perhaps old stock block had a mount? Old block is gone so no way to check. Any advice would help. Some say they are needed and some say they are not. It is 4x4 automatic please advise. Thank you
Old Mar 1, 2023 | 12:11 AM
It's been a while since I worked on one of those, but I think I remember them going to the motor mounts. Not necessarily to the same bolts that hold the mount to the engine, though. I thought there was a separate bolt hole.
Are you using the same mounts you took off? Are they on the same sides they came off of?
Sorry I don't have a better answer for you.
Old Mar 1, 2023 | 07:09 AM
There should be a plate between the motor mount and the block that had a tab on it for the bars to bolt to on either side.
The image below shows all of the parts on an '88 K5 which is all I was able to find readily, but should be the same as your '89:
'88 K5 Blazer Engine/Trans Mounting - image screenshot from nemigaparts.com
Old Mar 1, 2023 | 07:13 AM
Old Mar 1, 2023 | 09:10 AM
this diagram explains it all. Thank you. They guys that were helping do b the swap ommited these brackets when we put in the new motor mounts, hopefully they can be added back in. Thank you!
mr.vls
Feb 9, 2022 10:56 AM
ShannonF
Mar 2, 2014 08:24 PM
DoowBee
Engine & Internal
Oct 15, 2011 06:48 PM
hairybear44820
Aug 19, 2009 04:34 PM
zippy199
Jun 30, 2009 01:55 PM
