1990 k5 trouble
Old Dec 14, 2011 | 04:10 PM
dpbaseball95's Avatar
dpbaseball95 is on a distinguished road
Default 1990 k5 trouble
Hey everyone I do not know much at all about trucks. my blazer will not run. It will start up and die instantly. The only way itll stay running is if i keep pumping the gas peddle and even then it still barley runs. I have only replaced the fuel filter and the fuel pump is working fine and ive also cleaned the injectors. What could be the problem?
Thanks Dustin
Old Jan 19, 2012 | 11:34 PM
New Project K5's Avatar
New Project K5 is on a distinguished road
Try rebuilding the fuel regulator, its behind the injectors. Careful it has a spring in it, you can find on line how to do it.
Old Jan 22, 2012 | 07:13 PM
THePaRaSiTE5771's Avatar
THePaRaSiTE5771 is on a distinguished road
Could be the coolant temperature sensor that is causing your problem. It is up by the thermostat housing, to the left of it.
Old Feb 16, 2012 | 12:09 PM
steves88's Avatar
steves88 is on a distinguished road
I always try to start with the obvious. Fuel and spark. A new pump doesn't always mean good pressure. Do you have a fuel pressure gauge? Inspect the whole ignition system. Everything, wires, cap/rotor. Then move on to the others, sensors and such. Good luck
mustang2
Mar 28, 2008 10:05 PM
Boomer16
Performance & Brainstorming
Jan 8, 2008 02:03 PM
jdoerrer
Oct 15, 2007 01:11 AM
jdoerrer
Oct 14, 2007 09:35 PM
the fuel
Engine & Internal
Dec 15, 2005 01:25 AM
