1990 k5 trouble
Hey everyone I do not know much at all about trucks. my blazer will not run. It will start up and die instantly. The only way itll stay running is if i keep pumping the gas peddle and even then it still barley runs. I have only replaced the fuel filter and the fuel pump is working fine and ive also cleaned the injectors. What could be the problem?
Thanks Dustin
Thanks Dustin
I always try to start with the obvious. Fuel and spark. A new pump doesn't always mean good pressure. Do you have a fuel pressure gauge? Inspect the whole ignition system. Everything, wires, cap/rotor. Then move on to the others, sensors and such. Good luck
mustang2
Mar 28, 2008 10:05 PM
