3/4 ton rear end
apologizing in advance if this is the wrong area for this but here goes
I have a 89 k5 5.7 stock ten bolt rear my buddy has a 12 bolt 3.40 posi-loc rear for sale is this a decent up grade and is 3.4 low enough i have 33s on it now but was hoping to up them to 35s soon thanks guys
I have 3.73's with my 33's and I wouldn't go any lower than that with 33's. A 12-bolt is marginally stronger than a 10-bolt, but if you have to change the gears, that can get expensive.
I do believe that you could get the 12-bolt in a 3/4-ton or get the narrow-perch 14-bolt in the heavy 3/4-ton trucks back in the day. I have the rear from our old '75 heavy 3/4-ton that was a 14-bolt. It will bolt into the same location as a 1/2-ton axle.
itll be hard on the trans. first truck i bought had 273s and 38 inch tires. talk about a dog. i drove it like that for about a year too, eventually switching to 373s.
friend of mine gave me a 12bolt/dana44 combo said they were off a 77 3/4 ton pick up truck, no idea if thats the truth or not. i hate the 12bolts just cause they are a little rarer then the 10 bolts. customer brought one into the shop and needed a axle shaft, i thought one of my 10 bolt shaft from home would fit, nope. took a while to actually hunt one down
thewickedk5
Oct 22, 2011 12:18 PM
brino1
Feb 25, 2011 08:05 PM
Security
May 25, 2007 04:26 AM
