Will my computer from a 03 Blazer run a 366 6.0L from a 3/4 ton 3500?
Old May 24, 2007 | 01:43 PM
Security's Avatar
Security is an unknown quantity at this point
Default Will my computer from a 03 Blazer run a 366 6.0L from a 3/4 ton 3500?
I was just wondering if a 6.0 can be ran by my oem computer in my 4.3 Vortech 03chevyblazer LS2dr 4x4
Old May 24, 2007 | 02:03 PM
lastcoupe's Avatar
lastcoupe is an unknown quantity at this point
Default RE: Will my computer from a 03 Blazer run a 366 6.0L from a 3/4 ton 3500?
I would lean toward NO, but I haven't physically tried it.....I will tell you that both of these trucks have their own security systems which have to be programmed into the PCM. If it doesn't get the correct fuel continue password from the BCM it will not start the engine, or it will start briefly and die.
Old May 24, 2007 | 05:56 PM
drperry's Avatar
Also, the programming for the extra 2 cylinders isn't there...
Old May 24, 2007 | 06:56 PM
That, the associated additional wires, and figuring out how to manage the distributorless ignition all make for a fun and expensive endevour... But I will say this, if someone can take a Series 2 L67 and put it into an '89 Bonneville SSE as I've seen it done, this should definitely be do-able... Easy, no, but with enough time and money, it can be done.
Old May 24, 2007 | 07:13 PM
drperry's Avatar
Actually, putting the L67 into a bonnie is probably not as hard, as all you need is the wiring harness from the vehicle it came out of...
ODBI to ODBII swap is what that one comes down to... It's been done a fair number of times on the W-bodies... Swap a 3.1L or base 3.8 for the L67
Old May 24, 2007 | 09:23 PM
Shade's Avatar
Shade is an unknown quantity at this point
why cant you just take the computer from the truck you got the engine from? that will take a load of worries off your hands
Old May 25, 2007 | 04:26 AM
drperry's Avatar
Yeah, if you're gonna be pulling an engine from a truck, you want to get as much of the wiring for it as possible...
abig84
Jan 5, 2012 08:23 PM
thewickedk5
Oct 22, 2011 12:18 PM
matt92
Sep 13, 2011 10:11 PM
Doggpool
May 26, 2011 04:49 PM
