350 with TBI
Old Apr 9, 2011 | 10:09 AM
rich367's Avatar
rich367 is on a distinguished road
Default 350 with TBI
I have a 1989 full size blazer with a 350 TBI. It will idle fine but when you give it gas it falls on its face and will stall once in a while. I replaced the fuel pump assembly, fuel filter, all sensors and rebuilt the throttle body and still the same problem. It doenst show any codes. Any ideas??
Old Apr 10, 2011 | 10:29 PM
abig84's Avatar
ive seen issues like this when the EGR valve goes bad. my buddy had the problem where when he tried to drive normal with it or holding like 35mph it would die or run like crap. the egr was opening wide open at low rpms causing a huge vacuum leak
Old Apr 13, 2011 | 02:56 AM
wazzledoozle's Avatar
wazzledoozle is on a distinguished road
If you have a 350 you should probably get a EGR block off plate anyways
Old Apr 17, 2011 | 11:30 AM
helo's Avatar
helo is on a distinguished road
I bet your timing is off (retarded). You need to set it to 0* with the EST bypass unplugged (black plug, brown wire by wiper motor along firewall). You can usually rent a timing light at advance or wherever if you don't have one.
tech180
Feb 2, 2013 10:23 AM
deathman
Aug 14, 2011 11:25 PM
maverik78
Performance & Brainstorming
Apr 11, 2010 10:05 PM
blbikerood
Jan 19, 2010 10:05 PM
thebigo432
Headers, Intake, & Exhaust
Dec 17, 2006 11:18 PM
