4X4 Fuse keeps blowing
Old Jan 11, 2009 | 09:16 AM
rippersvf2's Avatar
rippersvf2 is an unknown quantity at this point
Default 4X4 Fuse keeps blowing
Hey guys,
I have a 1992 Full Size Blazer and this morning I was out plowing and everything was working fine. On my last pass up the driveway, the 4X4 stopped working. I tried to put it in and out of four wheel with the transfer case lever but it does not engauge. I checked the 25amp fuse and it was blown, i replaced it and the fuse blew again. Does this sound like i just need a new actuator? I just bought this truck , I hope its a simple fix.
Old Jan 11, 2009 | 09:18 AM
Default RE: 4X4 Fuse keeps blowing
I would say it is likely the actuator. You could disconnect the actuator and then try to engage it to see if the fuse blows. If not, then the actuator is the likely culprit. I probably would not rule out something binding up either. Have you thought about putting in a 30A fuse just for one single test?
*Moving to Fullsize Tech*
Also, there is no need to double post about your problem.
Old Jan 11, 2009 | 09:30 AM
rippersvf2's Avatar
Soory about the double post. I tried a 30amp and it got really hot, so i pulled it right out. Do I need any special tools to change the actuator??
Old Jan 11, 2009 | 07:10 PM
Did you try it without the actuator connected? If the fuse blows without the actuator connected, then it is a problem with the wiring grounding out. I have seen this more than once.
You should not need any special tools. If you do not already have the stepper motor version of the actuator, see about getting it. The old magnetic solenoid is prone to problems.
I have a shot stepper motor version on my bench right now that was taken out of my dads old 94 K2500. Reason it is shot is because it took a hit to a rock which cracked the case and allowed moisture to corrode contacts inside. Not a usual failure.
Old Jan 12, 2009 | 03:47 PM
rippersvf2's Avatar
I was thinking about just switching it out to a Posi-Lock system. What do you think?
Old Jan 25, 2009 | 03:04 PM
rippersvf2's Avatar
Default Update
Replaced the actuator with new updated factory one. Works like a champ! A little on the expensive side but worth it I guess.
Old Jan 25, 2009 | 04:22 PM
Default RE: Update
Good deal! Should work like a champ for a good long time.
I have that stepper motor on my work bench, but just have not had the time to screw around with it. I just got heat in my garage a few days ago and have been trying to get the exhaust system fit to the truck.
AustinBlazer
Jun 4, 2013 10:35 AM
rxhvn
Dec 17, 2009 08:03 AM
rippersvf2
Jan 11, 2009 09:27 AM
rippersvf2
Jan 11, 2009 09:18 AM
Garv
Jan 5, 2007 06:35 PM
