77 K5 Questions
Old Apr 28, 2009 | 04:51 PM
Woot!'s Avatar
Woot! is an unknown quantity at this point
Default 77 K5 Questions
Hey guys,
Haven't posted here in about a year but just have a few ?'s so rather than starting a new thread I figure'd I'd dig this one up.
So, I got the tranny in and it was acting quite weird right up front. It drove for a little while (15 minutes) but it kept acting like it was out of fluid but the dip stick showed that it was right on and finally it just wouldn't move at all. So, I parked it and it's been sitting for about a year and now that it's summer here I want to get it going. So my questions are this:
1. Is it possible that there is air in the fluid cooling lines?
2. What else could be causing my machine to be doing this?
3. Will 33x12.5x15" tires fit stock without a lift?
Thanks for the help!
-Kevin
Old Apr 28, 2009 | 06:58 PM
Moved to a new thread in the Full Size Tech section. The new member area is for new member introductions and not tech questions.
Where did this transmission come from? What is its history? Was the torque converter new?
33" tires will need to have at least a 3" lift to fit. 33x12.5's may need some fender trimming even with a 3" lift (mine did).
Old Apr 28, 2009 | 09:29 PM
bandidolenny's Avatar
Is the tranny slipping? If so then you will more than likely have to pull it.
33"s will fit with a 2.5" lift. 32"s will fit with no lift. 33"s with fender trimming.
vankuen
Sep 22, 2007 05:26 PM
