83 k5 starting issues
ok so i own a 83 k5 with a 350 and 700r4. Im having starting issues. I have replaced the starter solenoid, ignition switch, neutral safety switch, and battery cables and terminals. This is what it does, ill turn the key to the "on" and turn the key like id start it, the choke light comes on but as soon as the key is twisted all the way to engage the starter i lose all power battery gauge goes from 12-13 volts to 0, and i checked the battery and its reading right at 12.5 volts. Its done it before but id just leave it alone and waits a lil while then it would start up just fine again, i dunno what to do. another thing dunno if this is relevant but the seatbelt light used to come on when i turned the key to the "on" spot and doesn't anymore.
Erik
Erik
Is the ignition switch adjusted properly? My parts 'burban did the same thing. A little more tweaking on the ignition cylinder would allow it to start. Have you tried adjusting the ignition switch towards the steering wheel a bit further?
cgrett
Nov 15, 2010 09:08 PM
Sprocket
Mar 20, 2008 09:39 PM
dragonsdeath
Oct 7, 2006 01:08 AM
