84 6.2l
Old Jan 25, 2010 | 02:35 PM
scottystew's Avatar
scottystew is on a distinguished road
Default 84 6.2l
i need to figure out the gear ratio in my rear diff.
Old Jan 25, 2010 | 04:56 PM
abig84's Avatar
Pull your cover off and post the numbers. It will have numbers like 41 11. Which is the amount of teeth on the ring and pinion gear. After dividing them youll come out with 373. I hate going by the glove box cause you dont know if its been changed. You probably have 308 if its stock
Old Jan 25, 2010 | 07:57 PM
scottystew's Avatar
thanks ill check that when i get some time
Old Jan 27, 2010 | 12:20 AM
scottystew's Avatar
the rear diff went out is the reason i need to know so i can fix it. but i couldnt find the numbers and the oil was greenish? and anyways im pretty sure its stock the original bill of sale said it came with a posi and thats what it is
Old Jan 27, 2010 | 08:04 AM
Here is a picture (see below) of the numbers that abig84 is speaking of. You may have to rotate the ring gear around to find them.
This picture shows a GM Corp 10-bolt front axle, but if your rear axle is stock, it may be a 10-bolt as well:
Here is a shot of a GM Corp 14-bolt Full Floater I have in the shop now:
Old Jan 27, 2010 | 11:22 PM
scottystew's Avatar
see the problem is i cant turn it, its locked up
Old Jan 28, 2010 | 06:18 AM
You can probably count the teeth.
Old Jan 28, 2010 | 10:03 PM
abig84's Avatar
yeah sorry i wasnt more specific on where the numbers are i was probably posting from my phone and hate typing out long answers. if your able to see all the teeth on the ring gear and the pinion gear thats just as good as finding the numbers on the ring gear.
Old Jan 30, 2010 | 01:05 AM
old skool luvr's Avatar
not with the 6.2 in there, it'll be 3.42's. don't know why the diesel K5's & 'Burb's came with 3.42's (unless it was one of those M1009 CUCV military ones, i've heard they came with 3.73's as standard), but the gas trucks had the 3.08's as standard.
Old Jan 30, 2010 | 03:44 AM
scottystew's Avatar
its got 3.08 im pretty sure because it says it in my owners manual
