84 k5 cranks but wont start
Old May 18, 2016 | 02:10 PM
Yetimt41's Avatar
Yetimt41 is on a distinguished road
Default 84 k5 cranks but wont start
So i recently bought a k5 with a 350 and an edelbrock carb. I rebuilt the carb and slapped the carb back on to give it a go and it won't start up. It cranks but won't start. If I put gas in the carb and turn the key it starts right up but won't stay running. It'll run for a second or two. I took off the fuel line to the carb and stuck it in a can and turned the key for about 5 seconds and then went to the can to see if I'm getting gas and the can was a little over half full. Am I getting enough gas? What could be the problem?
Old May 18, 2016 | 03:12 PM
newguy's Avatar
sounds like maybe a carb rebuild problem. If it ran before the rebuild but not after. I would go through the rebuild again. You may have missed something
Old May 18, 2016 | 10:54 PM
Yetimt41's Avatar
It didn't run before i rebuilt it. I'm gonna take the op off the carb and recheck my floats. If that's not it what is it? Fuel pressure? Fuel pump?
Old May 19, 2016 | 01:17 AM
newguy's Avatar
I'm thinking fuel pump. Is it electronic? Not really familiar with 84 s. Could be wiring if it is. Just some things to check
Old May 19, 2016 | 05:07 PM
odat's Avatar
Check the fuel filter at the fuel inlet on the carb - some are a metal filter and they plug easy - some are a paper cartridge filter and the paper ones usually have a one way check valve inserted in them, make sure you have the filter facing the right way - Hate to admit it but over the years Yup been there done that on both instances
chevyokie
Aug 21, 2011 04:38 PM
bsbob
Jul 22, 2011 12:48 PM
nyjeepman
34
Mar 15, 2009 07:40 PM
josh05
Sep 22, 2008 12:21 PM
91Blazerblk
Sep 16, 2006 02:25 AM
