86 K5 won't start after warming up.
Old Apr 27, 2010 | 10:14 PM
Milli's Avatar
Milli is on a distinguished road
Default 86 K5 won't start after warming up.
starts and runs fine until it is up to operating temp, then for no reason won't turn over. lights and radio work and it doesn't happen every time either. I am able to do the screwdriver to the coil trick to get it running and then it seems like when it cools down , works fine again. please help, thanks
Old Apr 28, 2010 | 06:49 AM
1SLOW64's Avatar
1SLOW64 is on a distinguished road
starter solenoid might be going bad. Also check the battery ground.
Old Apr 28, 2010 | 06:51 AM
Is the timing set properly? I have my timing advanced pretty far on my K5 and it will turn over slow when trying to start it hot. But it always starts.
Is the starter original? Could be a weak starter.
Old Apr 28, 2010 | 11:15 AM
WalkingDown's Avatar
WalkingDown is on a distinguished road
Have the Battery checked.
My 86 was doing the same thing when I first got it fom my nephew. He said the battery was fairly new. brought into Shucks to test and sure enough it had a dead cell. Good news was I got a free replacement under warranty. Good luck.
Old Apr 28, 2010 | 03:06 PM
1SLOW64's Avatar
An easy fix for this is to install an ignition interupt switch(kill switch).
Turn it off while cranking then switch on while cranking. It will cure the slugish start from to much timing.
Old Apr 28, 2010 | 11:17 PM
a57chevy43's Avatar
a57chevy43 is on a distinguished road
That works. I used to use that on the old dirt track cars. I run 12.5-14:1 compression and one of the rules stated we had to use stock oem starters. We only had an ignition switch and starter button. With as much as 33-36degrees advance Oem starters didnt hold up long. Then a drag racer told me to spin the engine over then kick on the ignition. It does work. But the the guy posting the question here said it would start with a screwdriver on the solonoid. Doesnt that mean the battery and cables would be working ok cold or hot. My guess would be the small wire to the solonoid to might be loose or corroded.
Old Apr 29, 2010 | 10:35 AM
Milli's Avatar
thanks, I will check the little wire.
blazer485
Nov 24, 2013 09:42 AM
Xenon
Mar 6, 2012 06:03 PM
stormshadow1
Jan 3, 2010 04:24 PM
gohan69
Oct 4, 2008 12:34 PM
freakgt
Sep 14, 2008 11:25 AM
