87 350 TBI motor swap with built L-48 350
Old Feb 1, 2013 | 05:39 PM
tech180's Avatar
tech180 is on a distinguished road
Originally Posted by 1sttimejimmyowner
What are the specs on the L48?Has it been modded with a larger cam,are you running 202`s on humpbacks or do you have 882`s with 194`s or 202`s in them.Option c you are running aluminum headsLOL.
I am trying to figure out what heads these are. I cant find the casting numbers from the heads on any of the sites.
Maybe you guys can help.
Here are the numbers
9829
35548
And
9839
35548
Old Feb 2, 2013 | 10:23 AM
1sttimejimmyowner's Avatar
1sttimejimmyowner is on a distinguished road
What year is the block?The L48 is a corvette engine,the casting number will be inside where the valve covers go.I couldnt find anything on the numbers you got.The number should be 8-10 consectively.As for your eletric pump it should be ok.A good carb would be in the 650cfm range rather you go holley or eldabrock..Holleys are good for performance with the eldabrock you can jet it either way
deathman
Aug 14, 2011 11:25 PM
amorgan93
Aug 8, 2011 03:55 PM
maverik78
Performance & Brainstorming
Apr 11, 2010 10:05 PM
andrewhartley55
13
Nov 30, 2009 12:54 PM
douglasdolphin
Jan 5, 2009 08:25 AM
