87 Blazer won't start?
Old Jun 7, 2012 | 02:31 PM
Newhuis's Avatar
Newhuis is on a distinguished road
Default 87 Blazer won't start?
Hey guys. I've got a 1987 K-5 Blazer that recently has been having nothing but problems. The most recent problem is, I went to the gas station, put gas in, went to go start, starts, shut off. Went to go start it...nothing. I still have lights but no radio, no turn over, nothing..silence. Then my dad got it running again..the next day..same thing. What could be wrong?
Old Jun 7, 2012 | 06:35 PM
abig84's Avatar
ignition switch issue maybe. might be loose and your acc/on/start positions might be all jacked up
Old Jul 22, 2012 | 09:37 PM
Tobashadow's Avatar
Tobashadow is on a distinguished road
Check battery terminals, metal shrinks when hot and will lose connection when hot if not clean or tight.
Battery terminals
Terminals at starter
then finally ignition switch in that order.
Old Jul 23, 2012 | 11:20 AM
70-K5's Avatar
70-K5 is on a distinguished road
Check the Grounds too.
Make sure the group of wires that goes down the passenger side of the engine to the starter are not fried, I've had many problems with my 86 down there due to heat coming off the headers.
When you go to start it does it turn over at all and just whirrrr-whirrr-whirrrr? or does it do nothing?
Old Jul 23, 2012 | 07:50 PM
Willie'sBlazer's Avatar
Willie'sBlazer is on a distinguished road
Default won't start?
most likely your fuel pump or a modulator under the distributor cap.
andrewrj
May 6, 2012 07:28 PM
princered72
Sep 13, 2011 10:36 AM
Dark Rider
Aug 8, 2010 11:57 PM
1BSBAKER
Aug 11, 2009 10:54 AM
Irish10Hockey
Nov 13, 2008 02:48 PM
