88 FS fuel pump question?
Old Sep 18, 2012 | 02:08 PM
88BeachBlazer's Avatar
88BeachBlazer is on a distinguished road
Default 88 FS fuel pump question?
I have an 88 FS w/ the 5.7 and the fuel pump has quit on me. I'm looking to replace it but don't want to remove skidplate, hitch and drop tank. I want to cut a hole in the rear cargo area to access the tank. Does someone have the measurements to do this? Yeah I know, I'm cutting corners but as my name says this is a beach buggy that has been sentenced to a death via saltwater.
Old Sep 19, 2012 | 02:16 PM
70-K5's Avatar
70-K5 is on a distinguished road
I know guy's that have done it, don't know exact measurements. Since you'll have to patch with a different floor might as well eyeball a starting point and go at it with a big hole saw. figure out from there how wide you need to go to get good access. Enlarge as needed.
Old Sep 19, 2012 | 04:30 PM
Just don't cut through the supports under the floor! If you can look from the wheel well & see where the supports are, measure to the back lip. Then cut out the area between the supports.
I could take some measurements from the hole in the back of my '74 left by a previous owner, but I'm not sure if the supports are in the same locations on the newer trucks.
I'm going to end up making a flush mount cover using some stainless socket head flat screws to keep the access, but hide it just the same.
Old Sep 26, 2012 | 01:10 PM
I was hoping someone had the measurements but thats cool. I crawl under there and come up with them myself and post them up for future reference.
Thanks,
Rick
Old Sep 26, 2012 | 07:49 PM
abig84's Avatar
Thanks,
Rick
i think alot of people who do the hole cutting just start hacking away. one thing you can do what i did was use a small drill bit and just drill through somewhere where you think the sending unit is, when it goes through, stop so you dont go into the tank of course then look under the truck and see where the bit is and you can kinda measure from there where the hole needs to be cut.
BouncingRadical
14
Nov 27, 2015 12:30 AM
cide
Nov 7, 2009 01:26 PM
upblazer95
Mar 8, 2009 07:15 PM
Lckyctch
Dec 30, 2007 05:38 PM
mytruck2
Dec 13, 2006 04:50 PM
